X30 AF Problem
 you should have two settings, one macro and one super macro. if none works as explained here below, there is a problem and you camera needs servicing.
OFF Macro mode off icn_ff90-f2_20.gif MACRO Macro mode icn_ff90-g2_20.gif SUPER MACRO Super macro mode
The following restrictions apply in super macro mode: the lens must be zoomed out until the zoom bar turns white and the flash can not be used.
Use of a tripod is recommended to prevent blur caused by camera shake.
The shadow cast by the lens may appear in photos taken with the flash at very short ranges. Zoom out slightly or increase the distance to the subject.
See Also
