I think there's still a gap in the X lens lineup...
ark
I’ve been dithering about whether to buy the new 100-400. I keep thinking it would be fantastic for nature photography, but on the other hand it would weigh as much as the rest of my X-T1 outfit put together, and if I am going to carry that much weight around, I might as well use my full-frame Nikon.
This evening it hit me: The big gap in Fuji’s lineup is that the 55-200mm lens doesn’t accept the teleconverters.
So…What I really wish they would make is a 55-200mm f/4 or even 100-200mm f/4. I think 200 f/2.8 would be too big, though it might be possible. The real point is that the lens must be able to work with the 1.4 and 2.0 teleconverters. That would give 280mm f/5.6 or 400mm f/8, either of which would be workable for a wide variety of contexts.
For that matter, 100-250mm f/4 would be nice too. The main point would be f/4 at the long end while remaining substantially smaller and lighter than the 100-400mm.
There are third-party teleconverters which can be screwed into the filter thread of lens. Raynox makes a lot of such.
Edited by Vidalgo
Aren't you talking about macro lenses there?
Not macro but telephoto, screwed add-ons for extending of focal length. By factors from x1.54 to x3. You can see it here:
http://www.raynox.co.jp/english/video/selection/selection.html#telephoto
They make it for camcorders, but of course is possible to use with stills camera. IQ is another story.
Note the such converter is really big and heavy, and total setup can be disaster.
Lumens, you really know that you can't resist the inevitable GAS.
Tell me about it!  I just picked up the last lens I felt I really wanted, but now.......   That predicted 80 mm Macro that can incorporate the tele-converters REALLY looks interesting.  A 200 f2.8 could also prove quite interesting.  It never ends!  :)
The horizontal area you cover (at infinity) is 31m with a 200mm lens on an APS-C sensor. With a 300mm that is reduced to 20m. That's only 10m, or an angle difference of 2.25 degrees.
Is it bad or...? Sorry, I can not convert horizontaly covered area into distance between the camera and the subject.
That's why there is a lot of talkings about 200f2.8 prime with teleconverters.
Actually the rumor was for a 200 f/2 right?
http://www.fujirumors.com/rumor-fujifilm-working-on-a-xf200mm-f2-lens-source-right-in-the-past/
I would love to see that happen! A 200 f/2 with the X-T2 could be a great setup for sports, and longer primes are definitely an obvious gap in the lineup when compared to Canon and Nikon's offerings.
No, in many cases you can simply crop.
The difference between 200mm and 300mm is comparable to the difference between 135mm and 200mm.
Imagine tiny birds at 400mm which you already have to crop. Using 200mm will cause too much resolution loss again when cropping those.
And in some cases indeed one cannot get closer due to safety issues or physical barriers.
So you're all looking for exceptions to my "many cases" now? ;)
My guess is that many telezooms are used for compressed landscapes and for zoo or bird show pictures. In such cases the difference between 200mm and 300mm usually is not dramatic.
If cropping would always be an option, I would have written "all cases" ;)
Edited by johant
Johant, you are slipping.:-)
I am pretty sure that even my 500mm T2 has more than 31m horizontal view at infinte distance. I can easily take a picture of the moon and even get some environment in the picture and the diameter of moon is more than 31m, I believe and the distance is only a few hundred thousand km, by far not infinte.:-)
I guess your numbers refer to 1000m distance. They remind me to the view that specs of binoculars show for 1000m distance.
More related to the OP.
For long distance where you can not easily zoom with your feet to adjust the framing I prefer zoom lenses. So a fixed 200/2 would not be very intriguing for me. I would prefer a 100-200/2.8 which can be used with the converters.
Edited by Jürgen Heger
Yes, of course, I should have specified that I meant the hyperfocal distance, and not "infinity" ;) Which again doesn't say that much, because it is aperture value dependent (I used f/8) ...
But at 100m (wildlife distance?), the horizontal field of view becomes:
135.0    17m
200.0    12m
300.0    8m
500.0    5m
    • Hello, If you look in the top right-hand corner of each posting, there should be three dots in a row, like this —>  …  <—, click on them and after a moment or twelve, a small menu should drop down from the dots, the last entry in the menu is ‘Edit’. Choose that and after a moment or three you should be in edit mode for that entry. Note: Only you can edit your entries.
    • Jerry I found out it's a Cherry Blossom but I can't figure out how to edit it.
    • What is most ironic about this is that there must be many of us here that would be interested in significant ads about the products we're discussing. I would be. I normally hate ads, but relevant ones here would actually be somewhat welcome. What are the recent new Fuji product announcements? Is anybody offering a sale? How about 3rd party products? I mean, I actually want to spend money, more or less.
    • I don't think I have your answer, but it's worth trying. It's been a few days, are you still struggling with this? I've used Acquire (on an iMac) and an X-T4 (also an X-T5 and an X-T30 ii) and it worked, at least as far as backing up. No error messages, and a computer file with stuff in it. I understand you get an error message when you attempt to restore the camera from a backup, but, does it look to you like the backup phase is working? I mean, do you get a saved file and no error messages? Do you have any other Fuji cameras, and does it work for them? I have had problems getting Acquire to detect the camera. I did all manner of playing around with starting the software, plugging in the camera, and powering the camera on, in various orders (including what the instructions say). I always got it to work eventually, but it took lots of playing some times. Lately it fires right up. Somebody here commented on this difficulty and the security obstacles in the computer. Are you getting a connection easily, or after trying things, or not at all? Does Acquire show your camera model and the few settings it displays correctly?
