Still Life
Drake
I love the effect the 90mm lens achieves when shooting close up w/ wide apertures. I know that the Fuji is great for candids, portraits and landscapes, but I find this combination can be very effective for making still life images.
We have several fruit trees in our backyard and over the years, I end up shooting some of the fruit that ends up on our table.
A few others can be seen at my 500px account:
 https://500px.com/dapop
This is my X-T1 with an adapted 50mm Meyer Oreston f1.8 at f8 with the aid of a Kipon Tilt Adapter  and a bit of post processing in NIK.
fortune smiles to some and laughs at others
thyme (!) capsule
3 fallen tulip petals
in the fields
on second thoughts... ;)
X-Pro1 w/Zeiss 32mm f1.8 shot with a polarizing filter on a light table and one one the lens.
  • 5 months later...
I’ve got my eyes on you
Playing around with XPro 2 Advanced filter > Miniature setting - 18-55 with MCEX-16 extention tube
Edited by Drake
  • 4 months later...
  • 8 months later...
