Fujifilm Instax Share SP-2 Printer with Highly Welcome Improvements (Finally!!!)
Hello. Thankyou,now Is all more clear: I have take some time in you link. Let tell you.i was totaly forget this machine have "compress picture option" and not Only "compress lossless" anyway not change the experiment. RAW and this last two format look like same result about Number of recording picture. Can tell alll results in this: in raw you can make 17 pictures for second.Is wrong.Is about One single Press and wait buffer. Full 30/20/10/8 not change. After 17 Need Press again. You not can Press before "redgreen light recording Is on" With preshot you can have 25 are more 7 pictures The story change Only in jpg shot only. In jpg at 30 you have 30 picture but redgreen light off very Fast so you can shot very quicly. At 20 shot Is about start look like infinite shot. 60 So the best performance are this last One about Speed and recording picture after camera working witout big limit I want take a shot about Italy cyclet Just for passion. I think i Will use this last setting. After Need check when battery not are full change and ambient temp. Anyway my cam look like exactly specific about you link. Im Happy my cam working perfectly
By FrankWeiser · Posted
By JovialLich · Posted
