Using old Canon Speedlite 199A Flash
Hi,
I'm new to Fuji cameras world and this forum, actually new to digital photography.
I still use my Canon FD gears and film for photography and i love it but recently all E6 laboratories closed in my area and i need to use digital cameras for color photos (it's hard to find Pro color negatives here).
After some research i find a Fuji camera is that i need, a camera that be similar to film cameras in controls and ergonomic.
So i purchased a second hand X-E1 to have an experience and  if it be good i will go for better cameras like X-t1.
I like to use some of my old gears and already i have a FD convert ring for lenses, i just like to know can i use My Canon Speedlite 199A flash in manual mode with Fuji cameras?
http://www.mir.com.my/rb/photography/companies/canon/fdresources/shared/speedlites/199Aflash/index.htm
Edited by nDman
Yes, you can use the 199A on Fujifilm cameras.
In fact, you can utilize the 199A's on board auto circuitry to adjust it's own lighting. Just set the settings to reflect your camera's or vice versa. Some fine adjustments are required of course.
The 199A's flash temperature is slightly lower / warmer than modern speedlights so, you need to keep that in mind.
And oh yes.....the recycle time...... :rolleyes:
    • I do not use Flickr, so I do not know what their BB code is. All I did was copy the second link you provided, (starting at https: and ending at  _k.jpg — leave off the [img] and [/img] tags) and pasted it into the message. After a moment, a message popped up asking if I wanted to paste it as the image or as a plain link. I did this twice, the first time I had it paste in as the image and the second time as a link. Nothing fancy or tricky.
    • So do I just copy the BB code from flickr and paste it anywhere on the page like other forums or is there some other trick I need to perform to get it to post?
    • All software is the latest between camera and app. All settings are correct on camera. I have both lossless and uncompressed RAW files on the card in the camera. I have been up and down every reddit thread to no avail and am losing my mind… I’m doing all of the right things. It even sees my camera. It just doesn’t create the “drive” for it (see attached image screenshot).  Please Help!
    • Not sure how to delete threads, but I figured out what was wrong. In short, I was partially misunderstanding the view-mode's function. Also, the "+LCD Image Display" part requires that you have the Image Disp. setting set to anything but Off. Then it will display your last image on the LCD. If it's off, it's behavior will be exactly like the plain Eye Sensor setting.
