My vintage X70 (not for weak hearted)
By Astigmatism · Posted
Forgot to mention another thing. Mine does not work if I plug the USB cord into a USB hub. It only works if I plug the cord into one of the USB ports on my computer itself (an iMac). This surprises me because I think there's a hub built into the computer itself, which is how the computer has multiple USB ports in the first place. I think it was somebody here that suggested I try that -- sorry I don't remember who! -
On another forum someone suggested spraying some electrical contact cleaner into the wheel but the Fuji tech said that could risk frying the rest of the cameras electrical so I haven't tried that.
By sfainbraun · Posted
I have an x100VI with 1.01 firmware - did a reset already and didnt solve issue I am about to describe. Can you all see if your camera does this: Switch to C mode, step down to f16 and then press shutter half way. Does your screen go dark? I have tried playing will all settings (have had the following so quite familiar with the menus: x100, x100f, XT-2, X-Pro 2, XT-3) , only happens in C mode. If you find this can you report to Fuji @ digitalinfo@fujifilm.com. They told me they had not seen this before and that it was normal behavior because the shutter is closing, but the shutter closes in S mode as well. -
That’s a common problem with many cameras, filters irritating the autofocus.
I can't vouch for the Sigma on the X-S20 but I do have a Viltrox (27mm f/1.2) and the startup speed is identical to when I have the Fuji 18-55 on it.
