Survey: Most Used Fuji Lenses
FX Admin
Most Used Fuji Lenses (max. 2)
1,334 members have voted
  1. 1. Which Are your 2 Most Used Fuji Lenses?
    • XF 10-24mm F4 R OIS
      163
    • XC 16-50mm F3.5-5.6 OIS
      12
    • XC 16-50mm F3.5-5.6 OIS II
      11
    • XF 16-55mm F2.8 R LM WR
      146
    • XF 18-55mm F2.8-4 R LM OIS
      344
    • XF 18-135mm F3.5-5.6 R LM OIS WR
      106
    • XF 50-140mm F2.8 R LM OIS WR
      88
    • XC 50-230mm F4.5-6.7 OIS
      11
    • XC 50-230mm F4.5-6.7 OIS II
      23
    • XF 55-200mm F3.5-4.8 R LM OIS
      99
    • XF 100-400mm F4.5-5.6 R LM OIS WR
      43
    • XF 14mm F2.8 R
      100
    • XF 16mm F1.4 R WR
      117
    • XF 18mm F2 R
      86
    • XF 23mm F1.4 R
      249
    • XF 27mm F2.8
      96
    • XF 35mm F1.4 R
      316
    • XF 35mm F2 R WR
      222
    • XF 56mm F1.2 R
      190
    • XF 56mm F1.2 R APD
      13
    • XF 60mm F2.4 R Macro
      37
    • XF 90mm F2 R LM WR
      61
For me the 16-55 2.8 ... I liked the 18-55 which was good but then I tried the 16-55 and it was on another level, it made me really see the faults I had with at least my copy of the 18-55.
On top of this I also use the 90 f2, such a great lens I shoot a fair bit of motorsport and its ideal prime for trackside without having to lug around the 200 f2.
I will be getting the 23 f1.4 next as had tested it and gives lovely images.
  • 4 months later...
On 4/22/2016 at 8:17 PM, Jürgen Heger said:
23mm f/1.4 and 18-55mm f/2.8-4.0. But the Samyang 12mm f/2.0 probably was used more than the 18-55 in the last months since I had covinced Santa that the Samyang would make a nice Christmas present for me. In fact, when I put it on my wish list it was more to round up my focal lens range. I had never expected that it would become one of my most used lenses.
Therefore I would like to ask the administrator to add lenses to the list that are not manufactured by Fuji. I think all lenses that support full communication and function with the camera like the Zeiss Touit do defenitely belong on the list. The Samyang 12mm probably as well. According to this and other forums (or is fora really the used form?) the 12mm Samyang seems to be integral part of the Fuji lens line up even if Fuji themselves may see this differently.
Hey, i agree 100% with your favorite lenses and i also used the samyang frequently.
On 4/21/2016 at 5:32 AM, FX Admin said:
Hi folks,
here is another survey
Tell us wich are
Your Two Most Used Fujinon Lenses
Please vote above (multiple choice, please vote only two lenses) and
Comments welcome below
Keep In Mind: it's not about your favorite lens, not even about the lenses you own... this is all about the lenses you use the most overall!
Happy Voting!
Andreas & Patrick
My most used lens is not on the survey list.  Easily it is the 23mm f/2.
  • 1 year later...
On 4/22/2016 at 5:45 PM, Tikcus said:
35mm F/1.4 90%, then probably 18mm F/2.0 (then the 60mm F/2.4)
i was considering replacing my x100v with the 18 f2 on an xt30ii. same size or close enough. how does your 18 f2 compare to your 35 1.4? i also have and love the 35 1.4. obviously it won't give me the separation, but quality otherwise?
Edited by Luisdent
spelling
