Astro Photography
Yellerz
I would like to have a go at astro photography but don`t know much about it.  I have heard many say that the Samyang 12mm is the perfect lens for this.  Can anyone tell me why the Samyang is particularly suited to astro, is there something that makes this lens unique or is it the focal length that works, would my 10-24 be just as good or even the Zeiss 12mm.  :)
It's not the only lens that works for astrophotography, but it does indeed have some properties that make it, let's say, easier to get good results, depending on what you expect, of course.
I'll try to keep this short and simple, so there will be a few things I don't mention or won't go into great detail about. If I miss out on something that is of interest to you, please just mention it and I'll see if I can help.
In astrophotography, the subject is not very bright. In order to counter this, the gain (/amplification/ISO) as well as the exposure time need to be increased. With higher gain comes higher noise, but for starscapes, ISO-values between 3200 and 6400 will be needed anyway.
Instead of increasing the gain, the exposure time could be increased further. The problem with this is, the stars are moving. The longest exposure before the startrails become visible is approximately 500 seconds divided by the focal length (in 35mm-equivalent terms). Thus, it is beneficial if the lens that is used transmits a lot of light, has a low f-stop number. Depth of field is no concern, because the lens is focused at infinity.
And those two points are the reasons why the Samyang does fairly well with astrophotography: it is a very wide lens (18 mm in 35mm-equivalence), thus you can expose for 25 seconds before the stars start to form streaks, and it has a maximum aperture of f/2, which is one stop faster than the Zeiss and two stops faster than the XF10-24.
And finally, its optical characteristics are good for astrophotography: It has nearly no coma. Coma is an optical abberation that deforms points (stars) to slightly cross-shaped objects with a comet-like trail towards the corners.
Of course, all of this only helps if your goal are starscapes. If you want to take images of nebulae, you need a longer focal lenght. As said above, with a longer focal lenght star trails (and the movement of the sky in general) shows earlier. And longer focal lenghts often have a lower f-stop. therefore, you need a tracking device that moves your camera with the firmament.
  • 6 years later...
I loved my Samyang 12mmf2,  sold it and got the XF16mm1.4.  But now selling my 16mm to go back to Samyang.
It's easy to manual focus and takes great astrophotography shots. Also great for travel and skateboard photography.
@xftales
    • Welcome to the forum. Here is your image:
      If you copy the link and paste it in to your posting, you will be given the choice of having the link show up as the image (as above) or as just a link that can be clicked. https://live.staticflickr.com/65535/52678730517_54489efae3_k.jpg Great photo! Blue Jays are tricky to get good photos like you have, they tend to fly away as soon as the lens cap comes off 😀.
    • I own the Fuji X-T1 and X-H1. I own several Fuji lenses but I tend to use 3rd party vintage manual glass which I find quite enjoyable to use. I'm testing a photo here taken from my Flickr account that showcases the Tokina 100-300mm Zoom lens with 1.4 extender. [url=https://flic.kr/p/2og3ghr][img]https://live.staticflickr.com/65535/52678730517_54489efae3_k.jpg[/img][/url][url=https://flic.kr/p/2og3ghr]300mm 1.4 blue jay[/url] by [url=https://www.flickr.com/photos/92395202@N07/]frankweiser[/url], on Flickr
    • Forgot to mention another thing. Mine does not work if I plug the USB cord into a USB hub. It only works if I plug the cord into one of the USB ports on my computer itself (an iMac). This surprises me because I think there's a hub built into the computer itself, which is how the computer has multiple USB ports in the first place. I think it was somebody here that suggested I try that -- sorry I don't remember who!
    • On another forum someone suggested spraying some electrical contact cleaner into the wheel but the Fuji tech said that could risk frying the rest of the cameras electrical so I haven't tried that.
    • I have an x100VI with 1.01 firmware - did a reset already and didnt solve issue I am about to describe. Can you all see if your camera does this: Switch to C mode, step down to f16 and then press shutter half way. Does your screen go dark? I have tried playing will all settings (have had the following so quite familiar with the menus: x100, x100f, XT-2, X-Pro 2, XT-3) , only happens in C mode. If you find this can you report to Fuji @ digitalinfo@fujifilm.com. They told me they had not seen this before and that it was normal behavior because the shutter is closing, but the shutter closes in S mode as well.
