Cityscapes with Fujifilm X
Burb
Assisi  (PG) Italy the tower X100
Robo Cape Pourtgal  X100
X-E2 + 27f2.8
X-t1 10-24 @18mm   Duomo of Siena Tuscany Italy
10-24 @ 10mm piazza del campo Siena, Toscana, Italia
Edited by bergat
i campioni della toscana X-t1 10-24 @ 10mm
Capitol Museums Roma, Italia X-T1 10-24 @ 10mm
Holland a street of Amsterdam
X-T1 18-55
A city of England. X-100
Siena Italy The duomo church X-.T1 10-24 @10mm
X-E2 + 16-55
Roma, EUR X-T1 con 10-24 mm
Roma, EUR X-T1 With 10-24 mm
Sunset over Quebec City old town.
XT-1, 50-140mm@70mm, f/5,6
Fuji X100 Ischia (Naples) Italy
X100 Pourtgal
