Cityscapes with Fujifilm X
Burb
A couple of views of Porto's Dom Luís I Bridge that you'll need to explore a tiny bit to find!
I finally visited New York, with my trusty Fujis as travel companions :) !
X-E2 + 35f2
X-E2 + 23f2
X-E2+  23f2
X-E2 + 23f2
