Cityscapes with Fujifilm X
Burb
Hi, this is a blue hour shot from the Oosterhaven in Groningen, The Netherlands.
Taken with a Fuji-XE2 + Fujinon XF10-24mm, f/8, 30 sec. exposure at ISO 200, Lee ND 0.6 Hard grade filter.
Hendrix, if you look back through this topic there are numerous examples of no name locations! Post Nos 4,5,10,14,16,32,33 and 36!
Thankfully there are also many more that do give the location, are you sure you haven't snuck in and named lots of photo locations?
Regards Mike
Edited by Mike G
Hong Kong  X Pro 2
London, X100T.
Rome, Italy.
X-T2 & 35/2.
Tokyo // Shinjuku
Tokyo near Yoyogi Park
it is a stich of 10 exposures with the xf14mm
London, X-T10
