wedding shoot, recommendation needed for focus settings
shane
Hello Shane,
A wedding is a very important event, which can't easily be rewound and replayed for a re-shoot if you get the photos wrong.
My advice to you is, if you need to ask such a question, then perhaps it would be better to have the assurance of an experienced wedding photographer present to ensure backup for any mistakes.
You don't get a second chance at a wedding, and if you screw up through lack of experience, you are going to disappoint the wedding couple, their family and their friends, and possibly leave yourself open to a lawsuit.
In a church (down the aisle), a telephoto is not ideal.  You need 21mm or 28mm to allow for low light, and the depth of field and surroundings to give the photo some context.  You don't want to blur the background in the church, you want to include it.
Really, think very carefully about covering the wedding until you've followed experienced wedding photographers enough to understand what is expected, and to have enough experience not to screw up.  It's a BIG responsability :)
Hello Shane,
AGREED!  That is unless you know the couple and they've ASKED you to do the photography.
gentlemen,
Thanks for the advise regarding shooting a wedding, I do understand the stakes. Thy are clear, that they want me to do this. I do commercial work, and have shot fashion and event, so can perform when needed. I was just hoping for advice on the best focus options, my success rate with focus tracking is not impressive. I do better with back button focus, and manual focus.
regards
Shane
To answer what I think Shane was getting at...So far I've preferred AF-S with the low burst.  I've tried the continuous focusing mode but it was a little hit and miss.  I've only shot a couple of processionals with the fuji set up, but in decent light single focus worked fine for me.  I usually have two bodies on me...18mm and 35mm...or 23mm and 56mm...just depends a little on the venue.  I know with the AF-C focusing mode it's best to keep it to the 9 AF points in the center and do either the low or high burst mode.  The last one I shot with a x100t in AF-C and the x-t1 with the 35mm on AF-S.
I wasn't super familiar with the x100t and found it best to set everything manual on it.  For me when it was in Aperture priority or auto ISO, it made odd choices.  It did fine in AF-C and low burst in good light.  The XT1 did great as well.
I've shot on Nikon and Canon...while Nikon has the better AF speed and accuracy overall, I feel like the fuji does just as good as when I was shooting on the Canon 5d MarkIII.  Have fun, try to anticipate what's going to happen next, and have a lot of extra batteries.
Have you tried AF-C + zone 9 + Cl? This usually works great for me with such slow motion like aisle walking.
Back in manual focus days we were shooting with prefocus. Focus peak assist and continuous drive revive this technique for me.
gentlemen,
regards
Shane
I have the same type of concern. My plan is the 16-55 mm 2.8 with a mono-pod. My thought is a zoom will allow me to recompose faster than a prime lens as who ever is walking the isle gets closer to camera position. The one thing I am thinking is to get focus confirmation. On the back of the XT-1 their is a light that occasional blinks. It is for both the SD card recording and a Warning that the exposure is a problem. In short I know if it is blinking green on the back of the camera I need to change exposure or re-focus, something is wrong.
hey  newbie,
forget the zoom and monopod. you need a fast prime like the 35 1.4 or the 56 1.2 and zoom with your feet. I did testing, and it focused better when i walked backwards with the bride and groom. In the rehearsal I got to do testing in actual conditions
    • Hello. Thankyou,now Is all more clear: I have take some time in you link. Let tell you.i was totaly forget this machine have "compress picture option" and not Only "compress lossless" anyway not change the experiment. RAW  and this last two format look like same result about Number of recording picture. Can tell alll results in this: in raw you can make 17 pictures for second.Is wrong.Is about One single Press and wait buffer. Full 30/20/10/8 not change. After 17 Need Press again. You not can Press before "redgreen light recording Is on"   With preshot you can have 25  are more 7 pictures  The story change Only in jpg shot only. In jpg at 30 you have 30 picture but redgreen light off very Fast so you can shot very quicly. At 20 shot Is about start look like infinite shot. 60   So the best performance are this last One  about Speed and recording picture after camera working witout big limit I want take a shot about Italy cyclet Just for passion. I think i Will use this last setting.  After Need check when battery not are full change and ambient temp.  Anyway my cam look like exactly specific about you link. Im Happy my cam working perfectly
    • I do not use Flickr, so I do not know what their BB code is. All I did was copy the second link you provided, (starting at https: and ending at  _k.jpg — leave off the [img] and [/img] tags) and pasted it into the message. After a moment, a message popped up asking if I wanted to paste it as the image or as a plain link. I did this twice, the first time I had it paste in as the image and the second time as a link. Nothing fancy or tricky.
    • So do I just copy the BB code from flickr and paste it anywhere on the page like other forums or is there some other trick I need to perform to get it to post?
    • All software is the latest between camera and app. All settings are correct on camera. I have both lossless and uncompressed RAW files on the card in the camera. I have been up and down every reddit thread to no avail and am losing my mind… I’m doing all of the right things. It even sees my camera. It just doesn’t create the “drive” for it (see attached image screenshot).  Please Help!
    • Not sure how to delete threads, but I figured out what was wrong. In short, I was partially misunderstanding the view-mode's function. Also, the "+LCD Image Display" part requires that you have the Image Disp. setting set to anything but Off. Then it will display your last image on the LCD. If it's off, it's behavior will be exactly like the plain Eye Sensor setting.
