Streetphotography (open thread)
Mehrdad
I like these two pictures, but I don’t particularly appreciate, genetically being one, the characterization of someone of South-European or North-African looks as überhaupt “ mafioso”... unless you really know that it is the case and that he belongs to a criminal organization.
Life is already difficult as it is without stereotypes and even more with them.
I have quite a good eye spotting criminals (I have been working as a press photographer for over 7 years and encountered too many of them) and that guy waiting there with his tennis ball was one of them. I can assure you that. Ok, mafioso might be a bit exaggerated, but he wasn't just a regular pal either :)
If you say so. :mellow:
Actually Warwick that’s the way Hendrik called his picture , so no I am not seeing anything that the author didn’t put there himself.
"Mafioso @Tallinn, Estonia by Hendrik Osula, on Flickr"
You see things differently when you are on the receiving end of these things, believe me.
Ah. I didn't look at the title
X-E2 + 27f2.8
Busy
Finally Hot !!! :-)
X-E2 + 35f2
Sleeping rider
Hi everyone,
i am new to fuji and used it in London for my first shoots. Still having my DSLR, but love the quality and size of the XT-20
more pictures from London (with the XT-20) on my website.
I am an old (by age and usage...) X-PRO 1 user.
I know it's old, I know it's slow.... I don't care. For me it is the best camera I ever had....
Some shots to follow -let's start with something I call my Starbucks Affairs :-)
Hope you like it
London and Birmingham. XT2 23mm F2
Sent from my MHA-L29 using Tapatalk
