Fuji XT 1 and X100t for production stills
Old post but hope this can help. You have to make sure that exp. comp. is set to zero in P, S or A mode before you go in to manual mode. If the comp is set to, let say +5, and this is of the range for the settings in manual mode, twisting the comp dial (left dial) want do any changes.
By BokehBurger · Posted
I use my XT5 in full manual and the actual exposure does not match my viewfinder image. This just started to take place after owning the camera for over a year. I did a reset to factory settings, but to no avail. This is extremely frustrating, and I’m wondering if the metering system is faulty. Thoughts? -
Hey guys, The shutter on/off button switch may be loose on mine. After turning camera on and pressing the shutter/holding close to the area, the camera will turn off and say 'sensor cleaning'. This doesn't happen if I'm shooting via touch screen at all. Everything else is functional. Anyone else experience this before? Would love a much cheaper fix since Fuji Canada just quoted me $700 CAD to fix it, and considering everything else is functional except that part I'm not even sure why MPMB Main Board parts is being replaced😕 I got no explanation from them either.
